hsrp preempt command
Mar 13th, 2009
Hi all, if I have 2 routers, 1 pri and the other secondary, if the primary fails and r2 becomes active, if the primary comes back, will it not fail back to the primary unless I use the preempt keyword? do I need to configure this on both or only 1 router ?
mvsheik123 Fri, 03/13/2009 - 08:39
  • Gold, 750 points or more
It is enough to configure on the primary. it basically tells the primary to takeover the role (primary) when it come back onlne.
hth
MS
Harold Ritter Fri, 03/13/2009 - 08:45
  • Cisco Employee,
Carl,
This command is only required on the router with the highest priority (primary).
