Callmanger 6.1 ringtones
Mar 13th, 2009
I have a client that wants to set all ringtones back to default in the cluster and then restrict the selection to just the default. Can i modify the ringlist.xml like on previous versions and how to set all back to default, any ideas would be greatly accepted.
littledavewhite Fri, 03/13/2009 - 13:14
thanks for this but can anybody think of a way to default all phones back to default ringtone
Jaime Valencia Fri, 03/13/2009 - 14:00
there is no bulk process to do that, any way i can think of involves going to every phone.
factory reset or manual change are the ways, even using the phone designer is per phone process
if this helps, please rate
