WCS Upgrade 4.2 to 5.2 - Upgrade Linux First?
Mar 13th, 2009
Hi All,
I just attempted to upgrade our WCS software from 4.2.62.0 to 5.2.130.0. During the upgrade it kindly informed me that 5.2.130.0 is not supported on Red Hat 4. Therefore it would seem that I need to upgrade to 5.
But which task should i compelte first?
The linux upgrade or WCS?
The error mentions that 5.2 is not officially supported on linux 4. So does that mean I should do the upgrade to WCS and then upgrade Linux?
(I am not linux expert)
Appreciate any help
Overall Rating: 4 (1 ratings)
ericgarnel Fri, 03/13/2009 - 20:34
  • Gold, 750 points or more
It would be best
You also need to make sure that you have enough ram & free space as well
run /opt/WCS-4.2.62.0/Backup
copy the backup to another machine, cd, large flash drive,etc. for safe keeping
pop in the RHEL 5 CD or DVD, reboot
type linux upgradeany
ref:
http://www.redhat.com/docs/manuals/linux/RHL-9-Manual/install-guide/s1-upgrade-examine.html
Once the upgrade is complete, copy over the new WCS file, chmod a+x WCS-5.2.130.x.bin
then from the command line (in same dir as file) ./WCS-5.2.130.x.bin
(whatever the filename is) hit tab and it will complete it for you.
follow the prompts and once it is successfully installed run the following:
/opt/WCS-5.2.130.x./Restore
You will see it perform many migration steps.
It may fail on the first run, so be prepared to try again.
You can do it from the gui as well
It installs just fine on CentOS too
serotonin888 Thu, 03/19/2009 - 14:10
Thanks Eric
Sounds like a good plan. I will let you know how it goes.
Andy
serotonin888 Wed, 04/29/2009 - 23:43
Just thought I'd post back what we did in the end.
1) Backed up DB and Licenses files
2) Set up new VM Instance running Red Hat 5.3
3) Shutdown old physical server (as the license is tied to the hostname we couldn't have both servers running at the same time… I think this is something to do with Linux.. )
4) Change the name on the new server. Disable the redhat firewall.
5) Run the install script
6) Restore the DB (just remember to use binary FTP and not ascii when transferring the backup file. Ascii mode corrupts the tar file backup and you get an error during restore of “invalid distance code”)
7) Restart services
The license files are included in the DB backup. If the you don not change the host name to match the original you will not be able to start the WCS services.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
