Invliad boot configuration string on slave
Mar 13th, 2009
Hi All,
The Cat6513 with 2 Supervisor engine 720, has an issue with boot string configuration, Please refer the following output. (show dianostic sanity)
6513-01#show diagnostic sanity
Pinging default gateway 192.168.30.1
Sending 5, 100-byte ICMP Echos to 192.168.30.1, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/1/4 ms
Invalid boot image "sup-bootflash:s72033-ipservicesk9-mz.122-18.SXF11.bin" specified in the boot string on the slave.
Please check your boot string on the slave.
None of the images specified in the boot string on the slave are valid.
Please specify at least one valid image in the slave boot string to ensure the
slave is in a bootable state.
How do i configure the boot image for the salve?
Redundancy mode : SSO
6513-01#dir /all
Directory of sup-bootflash:/
1 -rw- 42827268 Jan 14 2008 17:02:55 -05:00 s72033-ipservicesk9-mz.122-18.SXF11.bin
6513-01#show boot
BOOT variable = sup-bootflash:s72033-ipservicesk9-mz.122-18.SXF11.bin,1;
CONFIG_FILE variable does not exist
BOOTLDR variable =
Standby is up
Standby has 458720K/65536K bytes of memory.
Standby BOOT variable = sup-bootflash:s72033-ipservicesk9-mz.122-18.SXF11.bin,1;
Standby CONFIG_FILE variable does not exist
Standby BOOTLDR variable =
Standby Configuration register is 0x2102
Thank you!
Leo Laohoo Sun, 03/15/2009 - 14:41
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
Can you do a "show boot"?
sivaprakasam81 Sun, 03/15/2009 - 14:50
6513-01#show boot
BOOTLDR variable =
Standby is up
Thank you!
