Click-to-Call from Outlook contacts with E.164 numbers
Mar 13th, 2009
All the phone numbers in my MS Outlook contacts are stored in E.164 format with a "+" at the beginning of the number. We have pushed our users to use this format as it makes calling from a Blackberry very simple regardless of where you are travelling to.
Cisco Click to Call has problems with this however (or maybe i haven't setup the dial rules correctly). I have tried the following settings (I am in the US):
"9" for outside line
"011" for international
If I then try to call +1 (212) 555-1212 click to call with try to dial 901112125551212, which obviously fails.
"-" for international
Click to call pops up a dialog box saying "+1 (212) 555-1212 cannot be converted to a valid phone number".
Is there a way to get this to work? I am running C2C and Call Manager
Tommer Catlin Fri, 03/13/2009 - 13:42
You need to create an Application Dialing Rule. In CUCM 5.x, it will ignore the + anyways.. so you need to create a dial rule.
11 digits
starts with 1
prepend with 9
strip 0
For for international, may have to play with it, or if you want a good reference to dial rules, check this link out:
half way down is a great table of dial rules for Application Dial Rules.
