show acls on router
Mar 13th, 2009
Does anyone know how to show multiple acl's that are configured on a router. I know how to run configure a show job and instead of doing a show access-list, I would like to show acls 7, 8 and 9. The documentation say to seperate each command with commas, which I did but when I click next, it does not go to the next screen. I can do a show access-list with no problems and start the job.
Overall Rating: 5 (1 ratings)
Joe Clarke Fri, 03/13/2009 - 12:36
Are you talking about using RME's Netshow feature? If so, what version of RME? How have you configured your Netshow job? Multiple custom commands separated by commas works fine for me in RME 4.2.
didentx01 Fri, 03/13/2009 - 15:06
Yes I am using RME's netshow feature. IT is RME 4.0.6. I am doing an adhoc job and you can put in multiple commands. I put in show access-l 7, show access-list 8, show access-l 9. Is this the correct syntax?
Joe Clarke Fri, 03/13/2009 - 23:22
The commands should be comma separated without any additional spaces. So:
show access-list 7,show access-list 8,show access-list 9
I tested that locally with RME 4.0.6, and it works.
