HWIC-4T1/E1 inter-op with HWIC-2CE1T1-PRI
Mar 13th, 2009
Kindly let me know if anybody have experience with HWIC-2CE1T1-PRI and HWIC-4T1/E1 interconnect end to end. it's possible to work or not. And what additional command required in order to used HWIC-2CE1T1-PRI full 32 channels.
Paolo Bevilacqua Fri, 03/13/2009 - 10:48
Yes these can interconnect, however you can configure a maximum of one single channel-group on the HWIC-4T1/E1.
You can instead have a maximum of 31 channels on any type of channelized E1 interface, because timeslot 0 is reserved for synchronization and CAS signaling.
