Crash Line
Mar 13th, 2009
Does anyone know the most efficient way to configure a crash line on a analog phone, connected thru a vg224 analog gateway?? I know it's possible but I cannot seem to find any literature regarding it online. Maybe I'm not using the correct terminology "crash line" but essentially a line that when you pick it up it automatically dials another number, without requiring any user input.
Thanks for the help.
paolo bevilacqua Fri, 03/13/2009 - 10:58
  • Hall of Fame,
    Founding Member
It's commonly called PLAR (Private Line Auto Ringdown). Configure connection plar XXX under voice-port.
AndrewG909 Fri, 03/13/2009 - 13:05
How would that work when using an analog line thru an analog gateway?? Would it be the same as if i was configuring a voip phone for PLAR??
paolo bevilacqua Fri, 03/13/2009 - 18:29
  • Hall of Fame,
    Founding Member
Yes, the configuration may be different but principle of operation is the same.
