Destination NAT from outside segment
Mar 13th, 2009
We have a router which connects 2 sites however for various reason the inside/outside are back to front in logical terms.
There is now a requirement to perform a static destination NAT however this needs to happen on the outside NAT segment.
Is this possible without reconfiguring all the NAT or should I consider a PBR ( not a CPU intensive router )
Any pointers would be helpful.
Jon Marshall Fri, 03/20/2009 - 12:17
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Andrew
It may be easier to help you if you could
1) draw a quick layout of the router connections
2) give some ip addresses as examples of what you need.
Jon
achrich Fri, 03/20/2009 - 12:56
hi - thanks for the reply. Managed to figure it out in the end.
