How to configure Slave Sup720 ?
Answered Question
Mar 13th, 2009
Hi All,
How to configure Stanby supervisor engine. I need to change the boot image string.
1118th307-6513-01#show diagnostic sanity
Pinging default gateway 192.168.30.1
Sending 5, 100-byte ICMP Echos to 192.168.30.1, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/1/4 ms
Invalid boot image "sup-bootflash:s72033-ipservicesk9-mz.122-18.SXF11.bin" specified in the boot string on the slave.
Please check your boot string on the slave.
None of the images specified in the boot string on the slave are valid.
Please specify at least one valid image in the slave boot string to ensure the
slave is in a bootable state.
Thank you!
Correct Answer by Giuseppe Larosa about 8 years 4 months ago
Hello Sivaprakasam,
yes it is fine.
Hope to help
Giuseppe
Overall Rating: 5 (2 ratings)
drolemc Thu, 03/19/2009 - 14:40
  • Silver, 250 points or more
You are hitting bug CSCsc98471.
Show diagnostic sanity fails to check software modularity boot string
This is a cosmetic issue with the "show diagnostic sanity" command.
You should manually verify the bootstring if using modular IOS
sivaprakasam81 Thu, 03/19/2009 - 15:09
How can i manually verify the boot string. This is my boot string vlaues.,
1118th307-6513-01#show run | inc boot
boot system flash sup-bootflash:s72033-ipservicesk9-mz.122-18.SXF11.bin
boot system flash slavesup-bootflash:s72033-ipservicesk9-mz.122-18.SXF11.bin
boot system flash slavebootflash:s72033-ipservicesk9-mz.122-18.SXF11.bin
Giuseppe Larosa Fri, 03/20/2009 - 04:25
  • Hall of Fame,
    Founding Member
Hello Sivaprakasam,
verify that the files at the different locations exist
do:
dir slavesup-bootflash:s72033-ipservicesk9-mz.122-18.SXF11.bin
dir slavebootflash:s72033-ipservicesk9-mz.122-18.SXF11.bin
if you get positive information the boot string is correct
Hope to help
Giuseppe
sivaprakasam81 Fri, 03/20/2009 - 08:00
I hope the reply is very positive,
6513-01#dir slavesup-bootflash:s72033-ipservicesk9-mz.122-18.SXF11.bin
Directory of slavesup-bootflash:/s72033-ipservicesk9-mz.122-18.SXF11.bin
1 -rwx 42827268 Sep 16 2008 14:18:56 -04:00 s72033-ipservicesk9-mz.122-18.SXF11.bin
65536000 bytes total (22470184 bytes free)
Thank you,
Correct Answer
Giuseppe Larosa Fri, 03/20/2009 - 09:04
  • Hall of Fame,
    Founding Member
Hello Sivaprakasam,
yes it is fine.
Hope to help
Giuseppe
