MPLS TE RSVP explicit problem
francisco_1
Level 7
Level 7
I have two routers connected in a lab via MPLS TE using RSVP. When i setup the tunnel to use explicit path-option
for example " tunnel mpls traffic-eng path-option 2 explicit identifier 2", the tunnel goes down and doesnt come up until i change it to use" tunnel mpls traffic-eng path-option 2 dynamic". Any ideas why this is not working?
R1
ip cef
mpls traffic-eng tunnels
interface Loopback0
ip address 150.1.1.1 255.255.255.255
interface Loopback1
description MPLS Traffic Eng
ip address 172.25.1.1 255.255.255.0
interface Tunnel0
ip unnumbered Loopback1
load-interval 30
tunnel destination 172.25.2.1
tunnel mode mpls traffic-eng
tunnel mpls traffic-eng autoroute announce
tunnel mpls traffic-eng priority 1 1
tunnel mpls traffic-eng bandwidth 100
tunnel mpls traffic-eng path-option 1 dynamic
interface Serial1/0
serial restart-delay 0
ip rsvp bandwidth 100
router ospf 1
mpls traffic-eng router-id Loopback1
mpls traffic-eng area 0
router-id 150.1.1.1
log-adjacency-changes
network 150.1.1.1 0.0.0.0 area 0
network 172.25.1.0 0.0.0.255 area 0
network 172.25.80.1 0.0.0.0 area 0
network 192.168.1.0 0.0.0.255 area 0
network 192.168.2.0 0.0.0.255 area 0
R2
ip cef
interface Loopback0
ip address 150.2.2.2 255.255.255.255
interface Loopback1
ip address 172.25.2.1 255.255.255.0
interface Tunnel0
tunnel destination 172.25.1.1
tunnel mpls traffic-eng priority 2 2
tunnel mpls traffic-eng bandwidth 200
interface Serial1/1
ip address 192.168.1.2 255.255.255.0
ip ospf priority 0
ip rsvp bandwidth 200
router ospf 1
router-id 150.2.2.2
network 150.2.2.2 0.0.0.0 area 0
network 172.25.2.0 0.0.0.255 area 0
Harold Ritter
Franco,
The most obvious reason would be that the explicit path you are using is wrong.
Could you please post the explicit path option and a "show mpls traffic-eng tu " when the tunnel fails to come up.
Harold Ritter
Sr Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
México móvil: +52 1 55 8312 4915
Cisco México
Paseo de la Reforma 222
Piso 19
Cuauhtémoc, Juárez
Ciudad de México, 06600
México
assuming this is what are tested:
interface Tunnel0
This configuration should correctly select the dynamic path. The path-option number could be called priority, with path-option 1 as 'best'
Could you post the "show ip explicit-paths" output. I couldn't locate the explicit path identifier 2 config from your running-config. May be you missed to configure the explicit path?
Sample config for R1:
Router(config)#ip explicit-path identifier 2
Router(cfg-ip-expl-path)#next-address 192.168.1.2
Explicit Path identifier 2:
1: next-address 192.168.1.2
Router(cfg-ip-expl-path)#do show ip exp
PATH 2 (strict source route, path complete, generation 3)
Vijay
