High CPU utilization ~30-40% Cisco 3600
Mar 13th, 2009
I have a router with multiple interfaces aggregating about 25Mb of traffic with a somewhat high CPU utilization. Ping times to the device fluctuate between 3ms and 180ms depending on the CPU load. We have WCCP directing traffic to a Barracuda web filter and have diagnosed that by disabling WCCP on the router, it does not lower the CPU load. I'm a little confused as where to go next. "show proc cpu sorted" shows most of the cpu 2.5ish going to virtual exec. Please let me know what information I can provide to help with this.
Giuseppe Larosa Fri, 03/13/2009 - 13:25
  • Hall of Fame,
    Founding Member
Hello Curtis,
according to
http://www.cisco.com/web/partners/downloads/765/tools/quickreference/routerperformance.pdf
a c3660 is capable of a max of 51-61 Mbps of traffic.
Other C36xy are less capable.
Traffic is forwarded using CEF but still the device uses its main cpu to move packets.
I think what you see is compatible with expected performance of the platform.
this should be the meaning of no cpu gain removing WCCP.
Hope to help
Giuseppe
