CUCM 7.X LDAP Integration
Mar 13th, 2009
Can you ONLY integrate CUCM 7.X with MS AD, Netscape or Sun ONE LDAP Server?
Those the ONLY LDAP Server types listed in CUCM Admin > SYSTEM > LDAP > LDAP SYSTEM.
Jaime Valencia Fri, 03/13/2009 - 14:22
  • Cisco Employee,
  • Hall of Fame,
    2011
i know it's also possible to integrate with
Novell, OpenLDAP and Tivoli Directory
http://forums.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Unified%20Communications%20and%20Video&topic=Unified%20Communications%20Applications&topicID=.ee835d2&fromOutline=&CommCmd=MB%3Fcmd%3Ddisplay_location%26location%3D.2cc02ba3
be aware we won't provide any kind of support as the ones you mentioned are the only officially supported LDAPs, all others options are classified as unsupported.
java
if this helps, please rate
