gbic question
Mar 13th, 2009
Regarding SFP GBIC's, will 1/2GB SFP GBIC's generally work in 1GB or 2GB capable equipment? I mean obviously it should work in equipment that is 1GB/2GB capable, but what about equipment that is only 1GB?
I am looking at Finisar FTRJ8519P1BNL SFP GBIC's to use in my 9216A's in the lab, as well as my Fortra and Xyratex storage arrays.
inch Sat, 03/14/2009 - 18:31
  • Bronze, 100 points or more
can you even get 1gb FC SFP's?
peter.ooms Thu, 03/19/2009 - 06:56
Obviously s/he can get or have them and me also as eBay-like-afterMarkets has lots of them :)
Serious, why no trying it. Equipment will not go broke. To my latest memory of access experiment, 1/2Gbics will work in 1Gbic only.
Goodluck and let us know.
Michael Brown Thu, 03/19/2009 - 14:37
  • Cisco Employee,
I believe that in the later SAN-OS versions, there is a checking that occurs and if the SFP is not one of the supported (generally this means sold by Cisco), the port will be disabled with a message 'Unsupported SFP'.
I would verify that the ones you are looking to put into the MDS, do indeed work before purchasing a large amount of them.
- Mike
bfeeny Thu, 03/19/2009 - 14:38
Thanks is there an official list of supported GBICs somewhere?
bfeeny Sat, 03/21/2009 - 18:28
Just so others know, I did use some cheap third party gbics (some agilent and finisar) and they did show "not supported" under "sh int fcx/y trans". However, they appear to work fine (although not supported). This is in my lab, so price was much more critical than being supported. I am not sure about performance, but from a features perspective everything seems to work as expected.
Brian
Trending Topics: Storage Networking
