03-13-2009 06:50 PM - edited 03-15-2019 04:51 PM
Hello specialists!
I have a problem with only one DID and 149 DIDs work fine.
There is a CallManager 5.1(2b) and gateway 2811 using h323 between CallManager and the gateway.
The calling party number is 24131611 and the called party (DID) number is 77201758, this DIDs is the only one with this problem.
I captured debug q931, if you can check it PLEASE:
*Mar 13 22:59:31.272: ISDN Se0/0/0:15 Q931: RX <- SETUP pd = 8 callref = 0x3C7C
Sending Complete
Bearer Capability i = 0x8090A3
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA98388
Exclusive, Channel 8
Progress Ind i = 0x8183 - Origination address is non-ISDN
Calling Party Number i = 0x0081, '24131611'
Plan:Unknown, Type:Unknown
Called Party Number i = 0x81, '77201758'
Plan:ISDN, Type:Unknown
*Mar 13 22:59:31.292: ISDN Se0/0/0:15 Q931: TX -> CALL_PROC pd = 8 callref = 0xBC7C
*Mar 13 22:59:31.320: ISDN Se0/0/0:15 Q931: TX -> DISCONNECT pd = 8 callref = 0xBC7C
Cause i = 0x80A9 - Temporary failure <<<<<<<HERE<<<<<<<<<<<
*Mar 13 22:59:31.392: ISDN Se0/0/0:15 Q931: RX <- RELEASE pd = 8 callref = 0x3C7C
*Mar 13 22:59:31.396: ISDN Se0/0/0:15 Q931: TX -> RELEASE_COMP pd = 8 callref = 0xBC7C
Any idea please let me know
Walter
03-14-2009 07:06 AM
Hi Walter,
Try to delete this DN and add it again
This may help
03-14-2009 06:16 PM
Thank for answering I already delete the DN 758 on the CallManager then I added to the test phone but the issue continues.
The DID call does not get through, I receive the Cause i=0x80A9 Temporary failure.
Walter
03-14-2009 11:06 AM
Hi Walter,
I would check a few things - make sure that this number isn't in a special device pool or partition, do a 'debug voip dialpeer' on the gateway for a good number and this number and see if you're hitting the same dial peers.
Then I would check for any specific translation patterns for this number.
Then I would start deleting/restarting things :)
hth,
nick
