ASA 5505 - Ethernet dead, console works
Mar 14th, 2009
Hi tere,
I'm having problems with an ASA5505.
It doesn't boot properly and all ethernet ports are dead.
Does anybody have a clue on whats wrong?
Launching BootLoader...
Default configuration file contains 1 entry.
Searching / for images to boot.
Loading /asa802-k8.bin... Booting...
Loading...
Processor memory 188293120, Reserved memory: 20971520 (DSOs: 0 + kernel: 20971520)
Guest RAM start: 0xd3800080
Guest RAM end: 0xdd400000
Guest RAM brk: 0xd3801000
IO memory 39403520 bytes
IO memory start: 0xd0fff000
IO memory end: 0xd3593000
Total SSMs found: 0
Total NICs found: 10
Unknown rev 15 Gigabit Ethernet @ index 09 MAC: 0000.0003.0002
Unknown rev 15 Ethernet @ index 08 MAC: 0021.d801.20b3
Unknown rev 15 Ethernet @ index 07 MAC: 0021.d801.20b2
Unknown rev 15 Ethernet @ index 06 MAC: 0021.d801.20b1
Unknown rev 15 Ethernet @ index 05 MAC: 0021.d801.20b0
Unknown rev 15 Ethernet @ index 04 MAC: 0021.d801.20af
Unknown rev 15 Ethernet @ index 03 MAC: 0021.d801.20ae
Unknown rev 15 Ethernet @ index 02 MAC: 0021.d801.20ad
Unknown rev 15 Ethernet @ index 01 MAC: 0021.d801.20ac
y88acs06 rev16 Gigabit Ethernet @ index 00 MAC: 0021.d801.20b4
Licensed features for this platform:
Maximum Physical Interfaces : 8
VLANs : 3, DMZ Restricted
Inside Hosts : 10
Failover : Disabled
VPN-DES : Enabled
VPN-3DES-AES : Enabled
VPN Peers : 10
WebVPN Peers : 2
Dual ISPs : Disabled
VLAN Trunk Ports : 0
Advanced Endpoint Assessment : Disabled
This platform has a Base license.
Encryption hardware device : Cisco ASA-5505 on-board accelerator (revision 0x0)
Boot microcode : CN1000-MC-BOOT-2.00
SSL/IKE microcode: CNLite-MC-SSLm-PLUS-2.01
IPSec microcode : CNlite-MC-IPSECm-MAIN-2.04
Panic: esw_init - esw_lmrvl_hw_init(): Could not load driver
gesadmin1 Sat, 03/14/2009 - 16:43
It's a possiblity that your unit is dead. Perhaps you need to open a case with TAC.
