Slingbox port forwarding
Mar 14th, 2009
Greetings -
Trying to access my slingbox from the internet. Unable to do so. I just want to make certain that my forwading looks good.
I miss anything essential from this snippet on my pix 501?
access-list SLINGBOX permit udp any interface outside eq 5001
access-list SLINGBOX permit tcp any interface outside eq 5001
static (inside,outside) tcp interface 5001 5001 netmask 0 0
static (inside,outside) udp interface 5001 5001 netmask 0 0
access-group SLINGBOX in interface outside
I assume this looks fine. If so my problem lies elsewhere .. shows that port 5001 is open
gesadmin1 Sat, 03/14/2009 - 16:42
Are you seeing the hitcount on the ACL being incremented?? Are you obtaining an ip address via dhcp for your Internet connection??
planzone Sun, 03/15/2009 - 11:05
Actually Yes I am seeing a hit count when I run a show access-list command. That is why I was confused on it was not functioning as expected.
However I resolved this issue. I simply had to "reset" the Slingbox device. I was questioning myself on the access-list commands as I am a bit rusty - thus why I posted it to this forum where as the folks here have a more of a clue then I do ;)
Thanks for replying!
