SPC tool problem
Mar 14th, 2009
  • Bronze, 100 points or more
now we testing new SPC tool for SPA942/922 version 6.1.5a for linux, but every time tool returning with [error code: 11]
What is error code 11?
if i use spa942-6-1-3-spc-linux-i386 tool every works fine
Thank you
Tomas
Alberto Montilla Mon, 03/16/2009 - 04:06
  • Cisco Employee,
Hi Tomas;
Thanks for highlighting the issue. Yes, we confirm this is an issue, and we are trying to correct is asap. As soon as we get the updated tool I'll let you know
Regards;
Alberto
Patrick Born Mon, 03/23/2009 - 13:52
  • Cisco Employee,
Hi Tomas,
We've corrected the SPC tools for Linux. Please download and try again.
Apologies for the inconvenience.
Patrick
Tomas Chott Mon, 03/23/2009 - 14:37
Hi Patrick,
where i can download repair version?
from Cisco Download page?
Tomas
Patrick Born Mon, 03/23/2009 - 14:46
  • Cisco Employee,
Hi Tomas,
Here's how to locate the current SPC tools:
1. Navigate to http://www.cisco.com/en/US/support/index.html [login required]
2. Search on device type, example spa962
3. Click Profile compiler [bottom of left column, Software Type]
4. Select the version that you want
Patrick
Tomas Chott Mon, 03/23/2009 - 14:49
Yes,
but there is only version from February
Tomas
Patrick Born Mon, 03/23/2009 - 16:08
  • Cisco Employee,
Hi Tomas,
The following Linux versions of the files were replaced:
  • SPA525G - 7.1.7 SIP
  • SPA941 5.1.8
  • SPA921 5.1.8
  • SPA901 5.1.11
  • SPA962 6.1.5a
  • SPA942 6.1.5a
  • SPA3102 5.1.10
  • PAP2T 5.1.6
  • SPA8000 6.1.3
The date on the server does not change because the posted file was overwritten.
Please download the versions you need and let me know if you experience any more difficulties.
Patrick
Tomas Chott Tue, 03/24/2009 - 08:52
Hello, there is log from SPC
spa962-6-1-5-a-spc-linux-i386
[initialization - MAC 00:0e:08:dc:dc:71] OK
[reading input file] OK
[run application] Error code: 126
[delete temp file #1] OK
[delete temp file #2] OK
[output of the application]
[run application] OK
spc: generated SPA942  encrypted cfg/00:0e:08:dc:dc:71.cfg   len=656 bytes
Tomas
Moderator Fri, 03/27/2009 - 08:24
Hi Tomas,
Were you able to solve the problem, or are you still having trouble? Please let me know so I can pass the message along if need be.
Thank you,
Cisco Moderation Team
Tomas Chott Fri, 03/27/2009 - 08:50
yes we have problem
SPC generating this error code - [run application] Error code: 126
Tomas
Patrick Born Fri, 03/27/2009 - 11:42
  • Cisco Employee,
Hi Tomas,
I spoke with the author of the SPC code and he does not know what error code 126 is.
Do you know what is outputting the error code 126? Could it be a custom script that you have developed?
I notice in your earlier post that you appear to use the same MAC address for the error producing 962 as you do for the 942 that does not produce an error code.
Can you please:
  • describe step-by-step what you do up to when the error code is produced?
  • send me a sample of the input file that you used that caused this error code? [paborn at Cisco.com
Patrick
