need a best router
Mar 14th, 2009
In my company i had 32 employees and they are provide with internet access through ADSL connection.
Now i need a router with NAT . Can you please suggest me the best router which is economical and must satisfy my requirments?
Leo Laohoo Sun, 03/15/2009 - 14:59
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
850 or 870 series router is a low end model but will do.
Data Sheet: Cisco 850 Series Integrated Services Routers
http://www.cisco.com/en/US/prod/collateral/routers/ps380/ps6195/product_data_sheet0900aecd8028a9a9.html
Data Sheet: Cisco 870 Series Integrated Services Routers for Small Offices
http://www.cisco.com/en/US/prod/collateral/routers/ps380/ps6200/product_data_sheet0900aecd8028a976.html
rajesh9002 Sun, 03/15/2009 - 15:18
Thank you for your reply ,i have seen the data sheet of 800 series router ,it is given that recommended number of users are 10.But i have 32 users. Can you please tell me other options.
Leo Laohoo Sun, 03/15/2009 - 16:24
  • Hall of Fame,
    2017 LAN, Wireless
The 800-series router is already End-Of-Sale. The 850/870 are the new generations of ISR's and these should be able to handle IPSec/VPN for 32 or more users without any hassles.
However, if you are still interested in slightly higher, please refer to the following links:
Integrated Service Routers Quick Look
http://www.cisco.com/web/partners/downloads/765/tools/quickreference/isr.pdf
Portable Product Sheets - Routing Performance
http://www.cisco.com/web/partners/downloads/765/tools/quickreference/routerperformance.pdf
Joseph W. Doherty Sun, 03/15/2009 - 17:00
Your performance is likely to be limited by the bandwidth of your ADSL. As long as the router effectively supports that much bandwidth, shouldn't matter whether there are 1 or 10,0000 users. (Of course, the more users, less bandwidth each gets if fairly shared. So, for more bandwidth, for more users, bigger router. [If you wonder how much bandwidth should be available per user, "that depends".])
Leo Laohoo Sun, 03/15/2009 - 16:41
  • Hall of Fame,
    2017 LAN, Wireless
Alternatively, please check out the interactive Cisco Product Advisor: http://www.ciscowebtools.com/ProductAdvisor/
Please rate when applicable.
