WLC2112 Trunk port issue
Mar 15th, 2009
I have WLC 2112 connected to a core switch,that port is configured as a TRUNK port,then the AP 1142 is connected to a Access switch,that port is configured as a Access Port.Now in this case the APs are not getting the IP address and not getting associated to WLC.
If I remove the TRUNK configuration in the Core switch,and configure as a simple Access port ,then the APs are getting associated to WLC and getting the IP address from the DHCP server,here the problem is multile VLANs are not able to get the association.
Please any can help me to resolve this issue.The WLC image version is AIR-WLC2100-K9-5-2-157-0-ER.aes.
Best Regards,
Lavanholy.
Overall Rating: 5 (1 ratings)
George Stefanick Sun, 03/15/2009 - 08:40
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Best Publication, October 2015
A few things :
1 Have you allowed the vlan in the trunk
2 Controller are you tagging the managment vlan or are you using 0?
3 Is your trunk config with the native vlan statement?
Lavanholy Sun, 03/15/2009 - 13:02
Yes I have allowed all VLANs for time being.
Yes configured as " 0 ".
This I will have to check it,I comme back to you after checking.O.k
Thanks for extending your support.
Best Regards,
S.Venkataraman
George Stefanick Sun, 03/15/2009 - 15:28
no problem. If you switch is NOT native and your controller is 0=tagging ... they will not connect ....
Lavanholy Thu, 03/19/2009 - 03:40
hi,
Thanks a lot ...s as u said after including the native vlan,it started working fine....thanks a lot...
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
