Warning message
Support for TDR cable diagnostics
Mar 15th, 2009
Dear friends,
The command test diagnostics cable-tdr interface <> does not seem to be supported on the new 4500 E-Series line card viz. WS-X4648-RJ45V-E. It says that the command is not supported on this module.
Is there any alternative to this issue that you could suggest
We are running 4500E with Sup 6-E and IOS ver 12.2(50)SG.
Thanks a lot
Gautam
gautamzone Sun, 03/15/2009 - 22:32
Thanks. But i already tried this command and it shows that it is not supported on this module.
The exact output that i received was :
%C4K_IOSDIAGMAN-4-TESTNOTSUPPORTEDONMODULE: Online cabl
e diag tdr test is not supported on module 1
The module that i am trying for is:
WS-X4648-RJ45V-E
Thanks a lot
Gautam
Leo Laohoo Mon, 03/16/2009 - 14:54
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
Hold on ... what is the syntax of your command?
"test diagnostics cable-tdr interface" for the 4500 is not valid. It's now "test cable-diagnostics tdr".
gautamzone Mon, 03/16/2009 - 22:31
Sorry, i meant that i used the command test cable-diagnostics tdr only. But it did not work.
Thanks a lot
Gautam
