Intigration between Call manager 5.1 and voice gateway 2811
Mar 16th, 2009
Hello
I am having cisco 2811 router with NM HDA module ,with VWIC2-4FXO,VIC-4FXS/DID. and cisco Call Manager 5.1 . now i want to integrate both system for router voice call to PSTN network to IP network visa-versa.Please help me out to configure and resolve the issue
Thanks In advance
Subhasis
Overall Rating: 5 (1 ratings)
david-lima Mon, 03/16/2009 - 08:09
Hi friend, initial steps:
CCM
1. Configure your gateway (h323 or mgcp)
2. Configure your route-patterns
3. Assign the partition, CSS, MRGL, Region, Location to your gateway.
GATEWAY
1. Initially, for making calls to the PSTN numbers, create a dial-peer pots with a destinatton pattern .T, the port should be your FXO port
dial-peer voice 100 pots
destination-patterns .T
port 1/0 (FXO port)
2. To receive calls from the PSTN to your IPT network, configure a connection plar pointing to an internal ip phone in your FXO voice port.
voice-port 1/0 (FXO port)
connection plar 1212 (DN IP Phone).
We can help you if you post your gateway configuration.
Hope this help
David
