ISDN PRI WIC for 1841
Mar 16th, 2009
Hi ,
I need to change one C2610 with a NM-1CE1U installed and one C2611 with a NM-1CE1B
I have a spare 1841 however I can not found a WIC card for that 1841 which can replace the NM cards.
Is there any ?
Many thanks
paolo bevilacqua Tue, 03/17/2009 - 09:56
  • Hall of Fame,
    Founding Member
There is none.
You need a minimum of a 2811 or the HWIC-1CE1T1-PRI, or you can try a VWIC on the 1841, thing is that you may not be able to configure data pri mode du to lack of DSPs.
