What is Virtual Ethernet/IEEE 802.3 interface
Mar 16th, 2009
In a 6513 core when i gave 'sh version'it shows the following
114 Virtual Ethernet/IEEE 802.3 interfaces
146 Gigabit Ethernet/IEEE 802.3 interfaces
here what does the 114 vitual ethernet interface mean ?. Could you please explain.
adamclarkuk_2 Mon, 03/16/2009 - 04:12
These will be the SVI (Switched Virtual Interfaces) you have configured on your switch ie
Interface Vlan 100
To see a list of them run the command :-
sh ip int | inc Vlan
Jon Marshall Mon, 03/16/2009 - 04:14
How many vlan interfaces do you have configured on your switch ie. if you do a "sh ip interface brief | include Vlan" how many are there.
Giuseppe Larosa Mon, 03/16/2009 - 10:42
Hello Padma,
in this count of gigabit port are counted also the ports that connect a service module to the backplane
see for example
32 Virtual Ethernet/IEEE 802.3 interfaces
96 FastEthernet/IEEE 802.3 interfaces
36 Gigabit Ethernet/IEEE 802.3 interfaces
1 Ten Gigabit Ethernet/IEEE 802.3 interface
in this chassis I don't have any tengiga external port the tengiga is the port of ACE module to backplane
And I have only 24 external GE ports
3 8 8 port 1000mb ethernet WS-X6408-GBIC
7 16 SFM-capable 16 port 10/100/1000mb RJ45 WS-X6516-GE-TX
but I have 4 GE ports between CSM and backplane
and 6 GE ports between FWSM and backplane
262 Po262(SU) - Gi6/1(P) Gi6/2(P) Gi6/3(P) Gi6/4(P)
271 Po271(SU) - Gi2/1(P) Gi2/2(P) Gi2/3(P) Gi2/4(P)
Gi2/5(P) Gi2/6(P)
2 6 Firewall Module WS-SVC-FWM-1
6 4 SLB Application Processor Complex WS-X6066-SLB-APC
the number of Virtual Ethernet is that of the Vlan interface
in your case it should mean you have defined 114 SVI vlan L3 interfaces
Hope to help
