routing descisions
Mar 16th, 2009
Hi all, can anyone tell me, If I have a router that has a static route pointing say the network at another hop, I then redistribute this into my eigrp network, If then on another remote location I setup the network and redistribute that into my eigrp network, will the router poiting the network add the more specific route into its routing table and it should work ?
Overall Rating: 3 (1 ratings)
JamesLuther Mon, 03/16/2009 - 05:46
Both routes will be populated into EIGRP and the more specific route will be used first.
So yes to your question.
