IPS Manager Express Reporting Question.
Mar 16th, 2009
Does IPS Manager Express build it's reports from the data on the Sensor's you are managing -- or the data it has downloaded from the sensors over a period of time?
I'm trying to figure out if IPS Manager Express keeps data on the box or always just grabs it from the Sensors & doesn't actually store it.
whhtnetwork Thu, 01/14/2010 - 09:40
Hi , I know this post is pretty old , I am still unable to find the answer you are looking for , where go IOPS manager express stores data , Because if i loose that data i cannot generate report for last month .... i can see one MYSQL folder , I think data is being stored into this and if we can copy this in the event of failure we just need to replace it , But no sure , Any one can help in this regards
