Enterprise vs. IPServices
ttieuropecco
right now we have here at our headquarter two Cisco 1812 in place for DMVPN. one is active and the other one is cold stand by. due to replacement of 19" racks we shifted the service over to the cold stand by unit. the cisco servers 17 tunnel endpoints without any problem.
then i realized that i have two different ios versions on these cisco routers. the original working one runs "c181x-adventerprisek9-mz.124-15.T5.bin" and the cold stand by one runs "c181x-advipservicesk9-mz.124-15.T5.bin".
both units run just fine with exactly the same startup-config. i could not find any differences serving our tunnel endpoints.
is there some kind of feature-matrix available, which outlines the differences between these versions? thanks a lot.
ct,
Hello Josef,
for a more detailed comparison of features I suggest to use the Feature Navigator Tool
www.cisco.com/go/fn
the tool can be used to compare two images providing two lists of features one for each image
Hope to help
Giuseppe
Giuseppe Larosa
Hello Josef,
se the following document that shows the relationships between different feature sets
http://www.cisco.com/web/partners/downloads/765/tools/quickreference/ciscoiospackaging-eng.pdf
advanced enterprise has more features then advanced ip services DMVPN is one of the features in common
Hope to help
Giuseppe
Hi Giuseppe,
thank you for the link. the document was quite helpfull and i got an small overview. but i'm still looking for some kind of matrix, which would show me in detail what parts are available in which versions.
ct,
Hello Josef,
www.cisco.com/go/fn
Hope to help
Giuseppe
Hi Giuseppe,
that was exactly what i was looking for. thanks a lot.
ct,
