Giuseppe Larosa Mon, 03/16/2009 - 06:29
  • Hall of Fame,
    Founding Member
Hello Moamen,
this error counter increments when frames that are correct at OSI layer 2 carry inside a protocol type that is not known or not running on the fas0/0 interface.
Example:
IS-IS packets are not ip packets we use it for routing, access layer switches count is-is hellos as unknown because they are not running IS-IS.
There are other possible reasons : ipv6 packets or layer 2 signalling packets like VTP or STP and others
if they increment regurarly over time like 1 one every 10 seconds or some every few seconds the reason is a not understood protocol.
if the number is not great you should be fine (no issues for your router)
Hope to help
Giuseppe
moamen.elhefnawy Mon, 03/16/2009 - 06:53
Thanks fr your help, just do you have any document on Cisco support that , as our customer need such document becuse he think it is a problem .
Thanks & BR
Moamen
eborcher Mon, 03/16/2009 - 13:12
  • Cisco Employee,
Can you provide us with the following output:
(1) show interface fastethernet 0/0 counter
(2) show interface fastethernet 0/0
(3) show version
