Cisco CCX 5.0.2 License file
Jonathan Schulenberg Mon, 03/16/2009 - 11:23
If you are asking for a license file, you will not get one posted on NetPro.
If you are a Cisco partner you can order the NFR kit which will provide you a PAK. If you are a customer, please work with your reseller to obtain timed licenses for evaluation.
Also, remember that UCCX is not supported in VMware (or any other hypervisor-based install). VMware ESX has been enabled in the platform validation to allow install but this is only for lab use.
