Upgrade from 2.6 to 3.1 failure
Answered Question
Mar 16th, 2009
I was upgrading from LMS 2.6 to 3.1 and my Putty session timed out and I lost connection to the server, this inadvertently killed the install i was running, I have found where it died, is there anyway to restart the upgrade, anyway to recover? If I cannot continue the upgrade can I uninstall what has already been upgraded and start again?
Correct Answer by Joe Clarke about 7 years 10 months ago
It depends on when the upgrade died. If it died after the message saying that you cannot abort after this point, then cannot restart. You will have to uninstall everything, and reinstall from scratch. If the upgrade died prior to that, you can simply restart setup.
If you do have to reinstall, it might be good to get the clean_system tool from TAC. This will purge LMS from the system. After that, you can install LMS 3.1 from scratch, and restore your 2.6 backup.
Overall Rating: 5 (1 ratings)
Correct Answer
Joe Clarke Mon, 03/16/2009 - 09:36
