EIGRP and IGRP lab
Mar 16th, 2009
I finished a CCNA course and managed to setup at home a small OSPF network, then moved onto a EIGRP network and all worked, however I have noticed we missed the IGRP routing protocol on the course. Is this just the same as EIGRP but internal on a LAN?
adamclarkuk_2 Mon, 03/16/2009 - 07:46
  • Silver, 250 points or more
IGRP is the older version for EIGRP. IGRP is a true distance Vector Protocol where as EIGRP is a hybrid protocol bringing the advantages of both models ( Link State and Distance Vector) into 1 protocol.
Here are some of the comparisons :-
# Both are Cisco Proprietary protocols.
# Both have same logic for equal cost paths.
# IGRP and EIGRP path selection is based on Bandwidth/Delay metric. Using some EIGRP commands maximum bandwidth can be changed as required while in IGRP it cannot be changed.
# Both have same metric accumulation, if divide the EIGRP metric by 256.
# EIGRP has fast convergence time while IGRP has a slow convergence time.
# IGRP sends full routing table during update while EIGRP does not.
# IGRP requires Distance Vector loop avoidance features while EIGRP does not.
# EIGRP uses Dual algorithm while IGRP uses Bellman and Ford algorithm.
# IGRP send periodic routing updates every 90 seconds while EIGRP send triggered change-based updates when there is a topology change has occurred.
I beleive that it has also been removed from the exam as it is being removed from new IOS versions aswell.
