Switch Catalyst 3750in Stack
Mar 16th, 2009
Hello, after UPGRADE IOS version to Stack of Switchs Catalyst 3750, one of them doesn't respond. See closer I notice that the front led SYST, is permanently blink in a green state. The other Switch of the STACK work OK.
When I log-in via console to the Switch I receive a "SWITCH:" prompt.
Please, someone can help me in this matter.
adamclarkuk_2 Mon, 03/16/2009 - 08:12
It sounds like your switch has failed to boot. check that the switch has an IOS in flash.
Run the following commands :-
dir flash:
Check that it has an valid IOS as it my have got currupt during boot up.
flielguera Mon, 03/16/2009 - 13:12
Hello, thanks for you response. I follow you instructions, the flash is ok, but the Switch showme a new message, I attach the messages of the Switch.
Leo Laohoo Mon, 03/16/2009 - 14:27
File "c3750-ipservicesk9-mz.122-50.SE.bin" could be missing from the directory. Please verify by typing the command "cd flash:c3750-ipservicesk9-mz.122-50.SE", then do a "dir" to see if the .bin file is present.
flielguera Mon, 03/16/2009 - 15:08
Hello, thanks for you response, I follow you instructions, the CD command doesn't work. I use the DIR command, like this:
switch: cd flash:c3750-ipservicesk9-mz.122-50.SE
Unknown cmd: cd
switch: dir flash:c3750-ipservicesk9-mz.122-50.SE
Directory of flash:c3750-ipservicesk9-mz.122-50.SE/
7 drwx 3648 html
411 -rwx 673 info
13451264 bytes available (2547712 bytes used)
Well, please, what is the next Step.
flielguera Tue, 03/17/2009 - 09:09
Hello, thanks for the procedures, but I have problemas to delete files into FLASH. I attach a LOG of my steps. As you see I can't delete a directoty of the flash to make room. How can do that ..??
