Callmanager - Issue for change time
Hi All
I have issue to change the time to a cluster with 2 servers 4.2.3sr1. windows 2000 servers
I made the change directly on the time of the servers and reset the phones. It not take effect, the phones keep showing an older time.
I check the ntp.conf file in both servers and seems ok, one with it self 127.127.1.1 and the other pointing to the publisher, I also reset the NTP services in both servers but nothing.
Please your suggests.
Andres
