MGCP Registration Issue
Mar 16th, 2009
hi guys,
i am getting strange problem while registering MGCP gateway with CCM 6.0 ... after configuring MGCP whn i try show ccm on gateway it showing me registered or Gateway in CCM it is showing unregistered ... after finishing the configuration on mgcp i did no mgcp and then mgcp so i got below errors "
NCBC-GW(config)#
*Mar 16 15:21:54.807: //-1/xxxxxxxxxxxx/MGCP/mgcp_check_hostname(8677):[lvl=0]Trying to validate endpoint name
*Mar 16 15:21:54.807: //-1/xxxxxxxxxxxx/MGCP/mgcp_check_hostname(8677):[lvl=0]Trying to validate endpoint name"
on CCM my endpoints are configured as NCBC-GW.ncbc.local (on GW ip domain name is ncbc.local)
if i type sh mgcp end points on gw
NCBC-GW#show mgcp endpoint
Interface E1 2/0
ENDPOINT-NAME V-PORT SIG-TYPE ADMIN
S2/ds1-0/[email protected]-GW
--More-- S2/ds1-0/[email protected]-GW
Interface E1 2/1
aaln/S0/SU2/[email protected]-GW
NCBC-GW#
NCBC-GW# and my mgcp config is
ccm-manager fallback-mgcp
ccm-manager redundant-host 10.32.64.3
ccm-manager mgcp
ccm-manager music-on-hold
ccm-manager config server 10.32.64.2
ccm-manager config mgcp
mgcp call-agent 10.32.64.2 2427 service-type mgcp version 0.1
mgcp dtmf-relay voip codec all mode out-of-band
mgcp rtp unreachable timeout 1000 action notify
mgcp modem passthrough voip mode nse
mgcp package-capability rtp-package
no mgcp package-capability res-package
mgcp package-capability sst-package
no mgcp package-capability fxr-package
mgcp package-capability pre-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp validate domain-name
mgcp validate call-agent source-ipaddr
mgcp rtp payload-type g726r16 static
mgcp bind control source-interface GigabitEthernet0/1
mgcp bind media source-interface GigabitEthernet0/1
mgcp rtp payload-type clear-channel static
mgcp profile default
can any one help me urgently plz
Rob Huffman Mon, 03/16/2009 - 09:06
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Nasry,
You mentioned the "endpoints" in CCM but what about the Gateway itself? Is it set for NCBC-GW.ncbc.local?
The Domain name issue is outlined nicely in this doc;
MGCP Gateway Registration Failure with Cisco CallManager
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a00805a316c.shtml#prob
If the IP domain name is configured in Cisco IOS on the MGCP gateway, enter the Fully Qualified Domain Name (FQDN) in the Domain Name field.
In the example: test and cisco.com represent the hostname and domain name respectively. If the IP domain name is not configured in Cisco IOS on the MGCP gateway, enter only the hostname of the MGCP gateway in the Domain Name field.
You would enter test.cisco.com (in CCM)
Hope this helps!
Rob
Tommer Catlin Mon, 03/16/2009 - 09:24
  • Green, 3000 points or more
can you post the rest of your router config?
Nicholas Matthews Mon, 03/16/2009 - 12:04
  • Red, 2250 points or more
Hi Nasry,
This may be very simple:
Make sure that 'sh ccm | i Name' matches what you've defined for the gateway.
Make sure that the physical layer of your PRI is up.
'show voice port summary' shouldn't show any bad states (very little if it's working right).
Some other random things:
no ip classless
if you're on a LI image: no mgcp lawful
hth,
nick
Ahmed Nasry Abd... Tue, 03/17/2009 - 14:12
Guys thank you so much for reply so fastly .... really appreciated ....
i think there is some problem in my network module ... i am using 3845 router and my module is NM-CE1T1-PRI ... if im doing show voice port summary .. i am not able to see voice port ..even in sh run my voice-port 2/0:15 is not there you can see.. more over on GW its showing that NCBC-GW.ncbc.local is registered with CCM but CCM is showing only ip of GW but status is unregistered ...
more over while adding GW in CCM i didnt find any module with the same name which i have .. in CCM only WICS or VWICS card are available but the one which i have (NM-CE1T1-PRI) is not there ,so i think i m selecting wrong NM .. how we can sure that i m selecting right NM or wrong NM ??? well my router config is
NCBC-GW#
NCBC-GW#sh run
Building configuration...
Current configuration : 6707 bytes
hostname NCBC-GW
card type e1 2
ip domain name ncbc.local
isdn switch-type primary-4ess
voice-card 0
no dspfarm
controller E1 2/0
pri-group timeslots 1-31 service mgcp
controller E1 2/1
interface GigabitEthernet0/0
ip address 10.10.10.1 255.255.255.248
shutdown
ip address 10.32.64.5 255.255.255.0
duplex auto
speed auto
media-type rj45
interface Serial2/0:15
no ip address
encapsulation hdlc
isdn bchan-number-order ascending
no cdp enable
interface Vlan1
no ip address
control-plane
voice-port 0/2/0
voice-port 0/2/1
voice-port 0/2/2
voice-port 0/2/3
voice-port 0/3/0
voice-port 0/3/1
voice-port 0/3/2
voice-port 0/3/3
voice-port 1/0/0
voice-port 1/0/1
voice-port 1/0/2
voice-port 1/0/3
voice-port 1/0/4
voice-port 1/0/5
voice-port 1/0/6
voice-port 1/0/7
ccm-manager mgcp
ccm-manager config
mgcp
mgcp sdp simple
end
below is show voice port sumary
NCBC-GW#sh voice port summary
IN OUT
PORT CH SIG-TYPE ADMIN OPER STATUS STATUS EC
0/2/0 -- fxs-ls up dorm on-hook idle y
0/2/1 -- fxs-ls up dorm on-hook idle y
0/2/2 -- fxs-ls up dorm on-hook idle y
0/2/3 -- fxs-ls up dorm on-hook idle y
0/3/0 -- fxo-ls up dorm idle on-hook y
0/3/1 -- fxo-ls up dorm idle on-hook y
0/3/2 -- fxo-ls up dorm idle on-hook y
0/3/3 -- fxo-ls up dorm idle on-hook y
1/0/0 -- fxs-ls up dorm on-hook idle y
1/0/1 -- fxs-ls up dorm on-hook idle y
1/0/2 -- fxs-ls up dorm on-hook idle y
1/0/3 -- fxs-ls up dorm on-hook idle y
1/0/4 -- fxs-ls up dorm on-hook idle y
1/0/5 -- fxs-ls up dorm on-hook idle y
1/0/6 -- fxs-ls up dorm on-hook idle y
1/0/7 -- fxs-ls up dorm on-hook idle y
NCBC-GW#
Thanks in Advance
b-gallagher Tue, 03/17/2009 - 14:35
Hi Nasry,
I don't see any isdn l3-bind ccm-manager command on the Serial 2/0:15 interface. If you manually configured this mgcp configuration then you may have missed the layer 3 back hauling necessary to bind the layer3 q.931 messages back to CCM. The interface will never come up without the bind statement and thus will not show registered
b-gallagher Tue, 03/17/2009 - 14:51
Hi Nasry, I also read somewhere that binding control and media messages only works to the loopback addresses for mgcp. I'll try and dig it out for you but it may be worth a try?
Tommer Catlin Tue, 03/17/2009 - 15:03
no, you can bind to eth or gig interface, loopback is not required.
I saw the L3 bind missing also in his config, but what is odd, is that T1 card he is using. Im not if its supported anymore.
Is this an old card you are re-purposing into a new router?
Ahmed Nasry Abd... Tue, 03/17/2009 - 23:39
Ok fine .. you all are right that binding command i have missed to configure on Serial 2/0:15 .... i will try it out by today and will come back to you guys ...
Ahmed Nasry Abd... Wed, 03/18/2009 - 08:00
Hi all guys,
finally i sorted out the problem, actually the problem was in module .. i changed module and register it ...it got registered in 2minutes .... and also before change the module i tried isdn binding command for CCM still with that it didnt work ...
Well thanks for all of you guys for your support and quick responce .. thanks alot for every one ...
