Jon Marshall Mon, 03/16/2009 - 08:48
Darren
Yes it's possible as long as you can identify the traffic you want to prioritize. But it does depend on the hardware in use. For example the 6500 switch uses many different modules and some of them do not support a priority queue as such.
What hardware are you using ?
Jon
darrenriley5 Mon, 03/16/2009 - 09:29
We are using ws-3750G-24TS to terminate 4x LES100 links and to connect to the EMC kit. I have no experience in the SAN but all I know is the srdf/s traffic runs across a non-routed vlan. I would imagine I would need to classify this traffic using the vlan then create an LLQ queue if this traffic were to be moved on to a shared link?
