How to merge the directories of 2 CUCM connected via ICT ?
Mar 16th, 2009
Hi out there,
We have two CUCM 6.1.2 on two different locations connected via an intercluster trunk.
A nice feature would be that side a can access the corporate directory of side b and vice versa.
Under CCM 4.1.3 it was possible by modifying the the directory file.
How can this be done under CUCM 6.1.2?
I already tried by copiing the content of xmldirectory.jsp from both CUCM into one file and let both access this modified file on a webserver but this doesn't work.
Either i get a parsing error or nothing happens.
Would be nice if somebody can help me.
Kind Regards
Christian
Overall Rating: 4 (1 ratings)
CHRIS CHARLEBOIS Mon, 03/16/2009 - 10:34
  • Silver, 250 points or more
How to do it depends on how you want it to look. You can offer the two directories as seperate options (i.e. Cluster A directory is option 4, Cluster B directory is option 5). That is actually the easier way to go. The other option is to combine the two, which would be more difficult.
CHRIS CHARLEBOIS Mon, 03/16/2009 - 13:01
If you want two seperate directories, I beleive it as easy as this:
Create an XML file (i.e "dual_directory.XML") and place it on an accessible web server.
In the XML file, put the following XML code:
<?xml version="1.0" ?>
Select a directory
Cluster 1 Directory
http://cluster1_Pub_IP:8080/ccmcip/xmldirectoryinput.jsp
Cluster 2 Directory
http://cluster2_Pub_IP:8080/ccmcip/xmldirectoryinput.jsp
Then go into the phone config from the CCM Admin page and point the Directories URL to the XML file you just created.
Sascha Monteiro Mon, 03/16/2009 - 10:53
you need to build a middleware application to take this task.
you can either;
- collect all users from both cucm's via AXL (listUsers,getUser)and put the in a vector or so
- on every search query both cucm's via AXL (executeSQLQuery)
The former is what I built for a client in a Tomcat Servlet, and is very fast (12ms search result), but the downside is that new users won't show up till next day (not a big issue though)
CHRIS CHARLEBOIS Mon, 03/16/2009 - 11:53
Would you need to get into AXL/SQL territory or could you acomplish the same thing using ASP and LDAP?
Sascha Monteiro Mon, 03/16/2009 - 13:11
you really have to get into AXL, well SOAP really.
you can probably use ASP for the phone facing pages, but you still need a backend to sync the users.
I have built it all in tomcat, so it's all Java built on the Spring Framework..it runs a Quartz scheduler to run the sync process..
christianluven Tue, 03/17/2009 - 02:23
Wow, the XML-File works!!!
Thank you very much.
But i have one last question.
Why is it completely in english?
If i use the default URL in the Enterprise parameters, the whole dialog is in german.
Where does the system decide to show me everything in english?
greetings
Christian
