Multilink Serial interface down after adding vwic2
Mar 16th, 2009
  • Purple, 4500 points or more
All,
We added a second vwic2 card to a 2800 series routerlast week, and noticed this morning that the S0/0:0 port is down on an existing multilink connection was down. We don't know if the addition had anything to do with it, but I'm not seeing where the problem lies.
I don't see errors on the serial interfaces either.
Multilink1, bundle name is IT
Endpoint discriminator is IT
Bundle up for 2d17h, 91/255 load
Receive buffer limit 12000 bytes, frag timeout 1000 ms
0/0 fragments/bytes in reassembly list
0 lost fragments, 0 reordered
0/0 discarded fragments/bytes, 0 lost received
0x0 received sequence, 0x0 sent sequence
Member links: 1 active, 1 inactive (max not set, min not set)
Se0/0/1:0, since 01:10:06
Se0/0/0:0 (inactive)
No inactive multilink interfaces
interface Multilink1
ip address 172.x.x.x 255.255.255.0
ppp multilink
ppp multilink group 1
interface Serial0/0/0:0
bandwidth 1544
no ip address
encapsulation ppp
ppp multilink
interface Serial0/0/1:0
bandwidth 1544
no ip address
encapsulation ppp
ppp multilink
show controlller T1
T1 0/0/0 is up.
Applique type is Channelized T1
Cablelength is long gain36 0db
No alarms detected.
alarm-trigger is not set
Version info Firmware: 20040802, FPGA: 13, spm_count = 0
Framing is ESF, Line Code is B8ZS, Clock Source is Line.
CRC Threshold is 320. Reported from firmware is 320.
Data in current interval (523 seconds elapsed):
0 Line Code Violations, 0 Path Code Violations
0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
Total Data (last 24 hours)
0 Line Code Violations, 0 Path Code Violations,
0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins,
show int s0/0/0:0
Serial0/0/0:0 is up, line protocol is down
Hardware is GT96K Serial
MTU 1500 bytes, BW 1544 Kbit, DLY 20000 usec,
Encapsulation PPP, LCP Listen, multilink Closed, loopback not set
Keepalive set (10 sec)
Last input 00:00:22, output 00:00:22, output hang never
Last clearing of "show interface" counters 2d17h
Queueing strategy: weighted fair
Output queue: 0/1000/64/0 (size/max total/threshold/drops)
Conversations 0/1/256 (active/max active/max total)
Reserved Conversations 0/0 (allocated/max allocated)
Available Bandwidth 1158 kilobits/sec
47276 packets input, 1087348 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
94628 packets output, 2934076 bytes, 0 underruns
0 output errors, 0 collisions, 4740 interface resets
1 carrier transitions
Timeslot(s) Used:1-24, SCC: 0, Transmitter delay is 0 flags
We've open and closed the serial interface, but it didn't help.
John
John Blakley Mon, 03/16/2009 - 09:30
The other end "show controller T1" output:
T1 0/0 is up.
No alarms detected.
Soaking time: 3, Clearance time: 10
AIS State:Clear LOS State:Clear LOF State:Clear
Data in current interval (607 seconds elapsed):
0 Line Code Violations, 278 Path Code Violations
0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 10 Degraded Mins
160 Errored Secs, 94 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
0 Line Code Violations, 42867 Path Code Violations,
0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 1440 Degraded Mins,
27072 Errored Secs, 10380 Bursty Err Secs, 2 Severely Err Secs, 0 Unavail Secs
Richard Burts Mon, 03/16/2009 - 09:47
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
John
A little while back I had an issue that was somewhat similar (especially in what seems to be a uni-directional problem - one end looks clean and the other end is taking errors, and the interface reports protocol down). In our case it turned out to be a problem in the provider network. It was a bit ambiguous whether it was really inside their network or whether it was at the smart jack.
I would suggest asking the provider to check the circuit.
Rick
