load sharing internet with two router
Mar 16th, 2009
I have Router cisco877 connect to ADSL, and route ENTRASYS connect to LL+,
the probleme that i need to share the connect to internet (backup)
Giuseppe Larosa Mon, 03/16/2009 - 11:22
Hello Armin,
you have a multivendor scenario
RIPv2 or VRRP are the possible options here
you can have RIPv2 running between the two routers and VRRP used to provide a virtual VIP to users in the lan segment.
for RIP
for VRRP
Hope to help
armingeorgeo Mon, 03/16/2009 - 15:34
Thank you Giuseppe,
but the problem that Router ENTRASYS don't support VRRP
please help
Giuseppe Larosa Mon, 03/16/2009 - 16:00
Hello Georgeo,
does the entrasys support RIPv2 ?
you can make use of the ICMP redirect concept:
if cisco router receives traffic it has to send to the entrasys it sends an icmp redirect to the host so that traffic for this destination is sent directly to entrasys.
you can enable it on Cisco router interface with:
ip icmp redirect
then all hosts should use as default gateway the Cisco router.
Hope to help
armingeorgeo Tue, 03/17/2009 - 03:08
thank you Guiseppe
the probleme that the router Entrasys don't support VRRP
armingeorgeo Tue, 03/17/2009 - 03:39
thank you guiseppe
plz send me if you have some configuration example for ripv2 load-sharing
