Implementing UBRL on a Cisco Catalyst 6500 with SUP 32 and 12.2(33)SXI IOS
Mar 16th, 2009
hello,
I'm tring to work with ubrl, User-Based Rate Limiting, on a Cisco Catalyst 6500, but im having strange beavior.
The 6500 have a SUP 32 WS-SUP32-GE-3B with a IOS (s3223_rp-ADVIPSERVICESK9_WAN-VM), Version 12.2(33)SXI, RELEASE SOFTWARE (fc2)
I'm trying to make a ubrl not autoritative, just to mark the exceed to a dscp with less priority, and a agregate flow to limit and police the all group.
When i do, for example:
police flow 400000 15500 conform-action transmit exceed-action policed-dscp-transmit
it works, but when i put a mask:
police flow mask dest-only 400000 15500 conform-action transmit exceed-action policed-dscp-transmit
it don't work, accept the command but do not limit.
Another error is trying to set the dscp:
SI-MSFC-SW(config-pmap-c)#police flow 400000 15500 conform-action set-dscp-transmit 8 exceed-action policed-dscp-transmit
QoS-ERROR: Modification made to policymap PRateInPorNat and class CRateInPorNat is not valid, command is rejected
if i try to directly modify the dscp:
SI-MSFC-SW(config-pmap-c)#set dscp 8
QoS-ERROR: Addition made to policymap PRateInPorNat and class CRateInPorNat is not valid, command is rejected
I have seen, on other examples, this output from when show mls qos:
Router# show mls qos
QoS is enabled globally
Microflow QoS is enabled globally
but on my 6500 it shows:
SI-MSFC-SW#show mls qos
Policy marking depends on port_trust
QoS ip packet dscp rewrite enabled globally
Input mode for GRE Tunnel is Pipe mode
Input mode for MPLS is Pipe mode
QoS is vlan-based on the following interfaces:
Fa6/10 Fa6/22 Fa6/26 Gi7/1
Vlan or Portchannel(Multi-Earl) policies supported: Yes
Egress policies supported: Yes
Its missing the "Microflow QoS is enabled globally".
I'm doing someting wrong?
The IOS 12.2(33)SXI on a SUP 32, supports Microflow and ubrl?
Some documents says yes to the SUP 32 and to the 12.2(33)SXI, but the combination of the two works?
I have to enable someting more?
Tank's in advance.
I have consulted
User-Based Rate Limiting in the Cisco Catalyst 6500
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps708/prod_white_paper0900aecd803e5017.html
Catalyst 6500 Release 12.2SXH and Later Software Configuration Guide - Configuring PFC QoS
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/ios/12.2SX/configuration/guide/qos.html#wp1571584
and much more.
Tank's
Luis Pisco
Serviços de Informática
Universidade do Algarve
