Using a router as an ACS server
mulhollandm
folks
i'm having problems with one of my acs appliances - i suspects its giving out duplicate IP addresses to users and therefore causing vpns to fail
i only have 8 accounts but each one represents a department in my organisation and the departmental account is used to validate a PPP connection
each department has a dhcp scope of 62 addresses allocated from the acs server
i'd like to temporarily replace the acs server with a router to see if the problem of duplicate addresses still occurs
the current acs server uses radius packets from an upstream nas
has anyone had to use a router for this purpose and if so are you aware of any config guides?
thanks to anyone taking the time to read this or reply
greatly appreciated
Jagdeep Gambhir
Level 10
Level 10
Yes, it is recommended to use router as dhcp instead of acs. Seen many similar issue with acs dhcp.
~JG
Do rate helpful posts
jgambhir
many thanks for your reply
can you point me to any guides
i suspect i could use the acs for authentication and hand over to a router for dhcp allocation
i would need to run 8 separate scopes
thanks again
