Giuseppe Larosa Mon, 03/16/2009 - 14:24
  • Hall of Fame,
    Founding Member
Hello Carl,
it is a dedicated interface that is at E1 speed, for the need to segment packets into ATM cells for transmission and to reassembly the original packet when receiving (ATM SAR) ATM cells.
several ATM E1 links can be bundled with ATM IMA.
Then comes ATM E3 34 Mbps PDH (in Europe at least)
ATM STM-1 155 Mbps
ATM STM-4 622 Mbps
Hope to help
Giuseppe
carl_townshend Tue, 03/17/2009 - 04:31
so, does the e1 physical interface have to be an ATM type ? instead of a normal g703 e1 interface ?
Giuseppe Larosa Tue, 03/17/2009 - 06:18
  • Hall of Fame,
    Founding Member
Hello Carl,
yes indeed an ATM interface not a normal E1 even if the cabling can be the same g.703
Hope to help
Giuseppe
Paolo Bevilacqua Tue, 03/17/2009 - 09:53
  • Hall of Fame,
    Founding Member
Actually the way ATM at 2mbps is done on the ISR routers, is with a "normal" VWIC, and the AIM-ATM module.
