Why my route-map did not set local-preference=200?
Answered Question
Mar 16th, 2009
Hey, can you help me understand this:
I setup a route-map to set local-preference to 200 if route is coming from 10.0.0.0/24 (ISP1), so I would make routes from ISP1 the preferred ones.
However, I see that my 'show ip bgp' lists only local-preference=100.
Why no routes were set to '200'?
Here is the the output from RouterB, the one I set the access-list 1 and route-map. Detailed diagram with run config is attached. Thanks in advance!!
RouterB#show ip bgp
BGP table version is 48, local router ID is 2.2.2.2
Status codes: s suppressed, d damped, h history, * valid, > best, i - internal,
r RIB-failure, S Stale
Origin codes: i - IGP, e - EGP, ? - incomplete
Network Next Hop Metric LocPrf Weight Path
*>i1.1.1.1/32 192.168.1.1 0 100 0 1803 i
*> 2.2.2.2/32 0.0.0.0 0 32768 i
*>i3.3.3.3/32 192.1.1.3 0 100 0 i
*> 10.0.0.0/24 0.0.0.0 0 32768 i
* i192.1.1.0 192.1.1.3 0 100 0 i
*> 0.0.0.0 0 32768 i
*>i192.168.1.0 192.1.1.3 0 100 0 i
RouterB#show ip access-lists
Standard IP access list 1
10 permit 10.0.0.0, wildcard bits 0.0.0.255
RouterB#
Correct Answer by Edison Ortiz about 8 years 1 month ago
As you noted, match ip route-source isn't supported as inbound policy under BGP.
This command is used for redistributing from one routing protocol to another:
http://www.cisco.com/en/US/docs/ios/iproute/command/reference/irp_pi1.html#wp1014124
If you want to increase the local-preference on routes coming from the 10.0.0.1 BGP peer, you simply create a route-map with local-pref 200 - apply this route-map under BGP inbound. For instance:
route-map LOCAL-PREF permit 10
set local-preference 200
router bgp 2000
no neighbor 1.1.1.1 remote-as 1803
neighbor 10.0.0.1 remote-as 1803 route-map LOCAL-PREF in
Then on the CLI, clear ip bgp * in
HTH,
__
Edison.
Overall Rating: 5 (1 ratings)
sunilferrao Mon, 03/16/2009 - 22:28
Hi ,
Try this
apply route-map SELECT_ISP out to ibgp peer
and do clear ip bgp soft *
news2010a Mon, 03/16/2009 - 22:53
Can you clarify how exactly I would apply the route-map out to ibgp peer?
Do you mean that I could do:
access-list 1 permit ?
sunilferrao Tue, 03/17/2009 - 00:05
under bgp 2000
neighbor 192.1.1.3 route-map SELECT_ISP out
rpfinneran Tue, 03/17/2009 - 03:35
  • Bronze, 100 points or more
I am guessing that you are matching ip address in your route map, then setting Local Pref.
That isn't what you are trying to do. What you should do is match ip route-source to ACL1. Then set local preference.
Paste your route map and BGP configs here and will resolve.
rpfinneran Tue, 03/17/2009 - 03:47
Yup, just realize you attached your configs. So, make the following changes on RouterB...
conf t
route-map SELECT_ISP 10
no match ip address 1
match ip route-source 1
exit
router bgp 2000
neighbor 10.0.0.1 route-map SELECT_ISP in
end
wr
news2010a Tue, 03/17/2009 - 06:16
I did as your advised. However, I got the message below between the "%" mark. Any ideas what's wrong?
RouterB(config)#route-map SELECT_ISP 10
RouterB(config-route-map)#no match ip address 1
RouterB(config-route-map)#match ip route-source 1
RouterB(config-route-map)#exit
RouterB(config)#router bgp 2000
RouterB(config-router)#neig 10.0.0.1 route-map SELECT_ISP in
% "SELECT_ISP" used as BGP inbound route-map, route source match not supported
RouterB#show route-map
route-map SELECT_ISP, permit, sequence 10
Match clauses:
ip route-source (access-lists): 1
Set clauses:
Policy routing matches: 0 packets, 0 bytes
RouterB#
Correct Answer
Edison Ortiz Tue, 03/17/2009 - 07:07
  • Hall of Fame,
    Founding Member
router bgp 2000
HTH,
__
Edison.
Harold Ritter Tue, 03/17/2009 - 06:16
  • Cisco Employee,
I would also recommend removing the BGP session to 1.1.1.1, as you already have a session to routerA (10.0.0.1).
news2010a Tue, 03/17/2009 - 11:15
Thanks. Regarding removing the session to the loopback0 (1.1.1.1), isn't the best practice establish session to loopback addresses for stability reasons? How do you handle it in this case? I am not sure if I could remove the session for the physical IPs and leave only the ones for the loopback in this case...
