Unable to access ASDM
Mar 17th, 2009
From My PC i am unable to access ASDM 5.X Version
Error is showing as ""unable to read the configuration from the ASA." . I'd really like to know what the problem is and why it can't load the config?.I have Installed Java Updated version in my PC and using IE 7. Do i need something?
Tnks
Ramu
solpandor Tue, 03/17/2009 - 05:30
what version of ASA IOS are you using and what version of Java?
try uninstalling the latest version of java and try jre 1.4.2
let us know how you get on
RamuChichula Tue, 03/17/2009 - 06:56
ASA version 8.0
Java version 6 (12)
I wl try as per ur suggetion and let u Know.
Tnks
Ramu
Richard Burts Tue, 03/17/2009 - 09:01
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Ramu
Your original post indicated that you were using ASDM 5.x. But if your ASA is 8.0 then you can use ASDM 6. My experience is that ASDM61551 effectively resolves the problem with the new version of java. It allows me to access ASDM to manage my ASA and to have the new version of java.
Rick
RamuChichula Tue, 03/17/2009 - 21:55
Tnks for your reply.I have tried to download that ASDM 6.X but unable to download due to not having necessary priviledges in cisco website.
Can u provide that version ASDM
Tnks
Ramu
Richard Burts Wed, 03/18/2009 - 10:15
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Ramu
Unfortunately it would be a violation of the licensing and our contract with Cisco if I provided the software to you. Perhaps you might contact the TAC and ask if they could provide the software as part of fixing the problem that you are having. Or perhaps there is a partner or reseller who can sell you a copy of the software.
Rick
