Route not advertising
Mar 17th, 2009
One of the route 10.31.1.0 is not getting advertise where all othere routes 10.31.2.0 and 3.0 are getting advertised.
I have checked the access list and all are ok
We have two links one is MPLS and other one is DMVPN
Just before 2 days we migrated from BGP to OSPF for DMVPN links then this problem started.
Now I am at strange can you give quick suggest me.
Naidu.
Richard Burts Tue, 03/17/2009 - 07:31
Naidu
There is not enough information here to really find the problem. It would help if you would post the config of the router where 10.31.1.0 is, and also it would be helpful if you would post the output of show ip interface brief from that router.
Rick
