Trunk between CUCM 7 and 4.3
Mar 17th, 2009
Dears,
I'm configuring a NonGwtekeeper Controlled trunk between CUCM 7 and CUCM 4.3
Calls from 4.3 to 7 are successful, but the reverse way is not working,
Kindly advice about that.
Overall Rating: 4 (1 ratings)
gogasca Tue, 03/17/2009 - 02:01
  • Green, 3000 points or more
Check Device Pool of trunks and remote IP address. (ie)
cluster A (cucm 4.3) 3 servers
cluster B (cucm 7.0.1) 2 servers
when u configure in cluster A, the ICT,
2 things:
a)ICT Device Pool should have the 3 servers in its CCM group.
b) Remote server should contain 2 IP addresses of remote servers
when u configure in cluster B, the ICT,
2 things:
a)ICT Device Pool should have the 2 servers in its CCM group.
b) Remote server should contain 3 IP addresses of remote servers
imadjabboury Tue, 03/17/2009 - 02:09
actually i didn't understand well what do u mean.
i only hve one CUCM 7.0.1 and one CUCM 4.3
anyway,
thanks for ur reply.
gogasca Tue, 03/17/2009 - 02:12
check Calling search spaces, locations and regions then.
imadjabboury Tue, 03/17/2009 - 02:40
i didn't configure any Calling Search Spaces, those are fresh servers, i'm doing test in our lab.
i did configure locations and regions.
first i need to know if this type of trunk should work successfully, and has been tested.
imadjabboury Tue, 03/17/2009 - 02:19
anyway,
gogasca Tue, 03/17/2009 - 02:37
Then it does not apply, check Incoming CSS for ICT Trunk.
R u using MTP required?
imadjabboury Tue, 03/17/2009 - 02:42
sorry for the inconvenience
the 4.3 server has configurations, but the CUCM 7 is a new one..
u meant incoming CSS on 4.3
