IPCCX Cisco Agent desktop work state button
Mar 17th, 2009
Dear All
I have a CRS 4.0(5) with CM 4.2(3)
I am facing a problem with work state button on Cisco Agent desktop.
I cannot use this button it is gray
and agents go on work state only by automatic wrapup time after ending a call
SO if anyone have any idea or a clue
Jonathan Schulenberg Tue, 03/17/2009 - 07:07
  • Cisco Designated VIP,
    2017 IP Telephony
The work state button is only enabled during a call. Are you saying that while on an ACD call, the Work button is disabled?
If so, check to ensure that it has not been manually disabled within the workflow group of CDA.
ayman_sheta Sun, 03/22/2009 - 08:34
Dear Sir
Thanks for your reply
But I have the Work Button gray out in both no calls for agent or while agent is on a call
I also check that the work Button is visible from Cisco Desktop Admin
So If you have any idea, I would appreciate it
BRs
