Assign WLAN to AP
Answered Question
Mar 17th, 2009
we have a Cisco WLC and created some WLANs. All is working fine. We have a H-REAP AP at a remote location. We don't want to assign all available WLANs to this AP. Is it possible to assign only special choosen WLANs to this AP?
Correct Answer by Scott Fella about 7 years 10 months ago
You can use the wlan override feature on the AP 802.11bgn and 802.11an under the wireless tab on the wlc. Check only the ssid's you wish to have on each radio.
Overall Rating: 5 (1 ratings)
Correct Answer
Scott Fella Tue, 03/17/2009 - 05:07
David Wagner Tue, 03/17/2009 - 14:29
Thank you. That's what i`ve searched for.
H-REAP: 100 ms max latency between the WLC and AP may not exceed. Is it the same for local switching and local authentication?
Scott Fella Wed, 03/18/2009 - 06:22
I would say yes, but again, that is considered best practice. Depending on the bandwidth at the time of authentication might be more of an issue. I have clients with h-reap ap's all over and no issue, but only few running over 100msec.
