Route not advertising (Urgent)
Mar 17th, 2009
One of the route 10.31.1.0 is not getting advertise where all othere routes 10.31.2.0 and 3.0 are getting advertised.
I have checked the access list and all are ok
We have two links one is MPLS and other one is DMVPN
Just before 2 days we migrated from BGP to OSPF for DMVPN links then this problem started.
Now I am at strange can you give quick suggest me.
Naidu.
Giuseppe Larosa Tue, 03/17/2009 - 05:35
  • Hall of Fame,
    Founding Member
Hello Naidu,
compare the state of two routes using
sh ip route prefix
sh ip bgp prefix
you should see some differences between an advertised prefix like 10.31.2.0 amd the troubled subnet 10.31.1.0.
you are still using BGP on the MPLS links ?
Hope to help
Giuseppe
ilnaiduccna Tue, 03/17/2009 - 22:24
Hi Guiseppe,
Yes we are using BGP on the MPLS links and provider taking care of it.
The remote router (Rome) connected through MPLS, its able to speak with other site MPLS router (Odense).
In the same way we have one DMVPN router at Odense and this one only not advertising route to router at Rome.
Naidu.
