ipsec over udp (NAT/PAT) not working on ASA5520
Mar 17th, 2009
i configure remote access vpn on ASA5520 , it is working fine with ipsec over tcp but i can't connect when change to ipsec over udp (NAT/PAT)
urgent help needed
Richard Burts Tue, 03/17/2009 - 09:05
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Mohammed
Posting your config would be a good place to start. Perhaps output from the log showing what happens when you attempt to connect with via UDP would also help. If that does not show us the issue then we might need output from debugs.
Rick
