adamclarkuk_2 Tue, 03/17/2009 - 04:00
You will need to create (add) the vlans before assigning ports to them (although it will take your config).
Depending on ios/model of switch, there are 2 ways to do this.
From global configuration mode :-
switch(config)#vlan 500
switch(config-vlan)#name
switch(config-vlan)#exit
OR
switch#vlan database
switch(vlan)#vlan 500 name
switch(vlan)#apply
switch(vlan)#exit
Once you have created the vlans, you will be able to assign them to interfaces.
glen.grant Tue, 03/17/2009 - 04:22
If you do a "show vlan " command and they show in the display as active then they are already in the database , other create them as the previous poster indicated.
